Struts Help please!!!
Old Nov 8, 2011 | 11:53 AM
ramrit52's Avatar
Default Struts Help please!!!
I have a 04 4 cylinder honda accord. Im trying to buy performance struts and i was wondering if the coupe v6 model of the same year accord would fir my car. NEED response ASAP!!
Old Nov 9, 2011 | 12:32 PM
g22cd5's Avatar
Supper Moderator
check the part numbers for your OEM struts then do the same for the year and mode v6 accord. See if they match at all. The spring rate will be different since the v6 is heaver up front than the 4cyl. But as long as the bolt pattern is the same you should be able to swap. I know for the 90-97 accords all the suspension components are all interchangeable...I don't know much about the accord after 97 (I also don't care to either) so I'm not sure what all can be swapped and what can't
Old Mar 8, 2014 | 12:47 AM
My oh4 accord's Avatar
I think they v6 ones I'll be a heavier duty one but should interchange I have 04 v6 but if the set up is the same then I would go for it. U doing the work urself? Then ask a part store if they r interchangeable if ur paying anshop they should be able to find out for you
striker911
May 20, 2009 02:18 PM
jllaneta
Oct 21, 2008 12:29 AM
junker
Oct 6, 2008 04:31 PM
BostonPuppyDawg
Oct 3, 2006 01:24 AM
dj.fli4rt
Oct 10, 2005 12:05 PM
