subframe bushing or strut - 98 accord
Old Aug 31, 2016 | 12:36 AM
brjr1's Avatar
Default subframe bushing or strut - 98 accord
my 98 accord 4 cyl has had the lower front ball joints replaced on both side. I had the front motor mount replaced. After that it is still making a rattling noise under the front of the car.
the guy who replaced the motor mount noticed one of the nuts from the subframe was backed out a bit so he tightened it and claimed that the bushings (or lack thereof) is what is causing the noise. Since I could not find any from advance/auto zone/amazon, I went to an auto shop who lifted the car and showed me a bushing (or something) at the top of the drivers side strut is separated.
1. what would cause the nut on the subframe/body mount to back off?
2. are there bearings between the subframe and frame? if so, why can't I find any?
3. could the strut be the only source of noise under the car?
Old Aug 31, 2016 | 12:31 PM
The first picture is the stuff at the top of the front shocks. Do you see the part that's loose or broken?
There are bushings between the subframes & the body. Maybe they are dealer-only parts?
Look at the 2nd picture. There's a large cross-beam (#1) at the lower control arms. There's also another cross-beam (#9) closer to the radiator. I think those 2 are bolted to each other without bushings, but the bushings are between each of them to the car body.
Oh yeah... your 3rd question. I wouldn't presume that you have ONLY ONE source of noise. You have to look at any of the possibilities.
Attached Thumbnails subframe bushing or strut - 98 accord-1998-frontshock.gif   subframe bushing or strut - 98 accord-1998-subframes.gif
Old Aug 31, 2016 | 08:27 PM
brjr1's Avatar
For the strut, looks like #11. I should've taken a picture
I'll go to the dealer tomorrow and ask about those bushings.
Thanks
Old Sep 23, 2016 | 10:25 PM
brjr1's Avatar
Can someone help me with this? Why is it that items 6-8 are not available for a 4cyl AT accord (98) though the schematic is for an accord?
Items 50231-S87-A00, 50232-S87-A00 and 50232-SL4-000
Old Sep 24, 2016 | 10:27 AM
Have you tried looking up a "strut mount" for your accord?
Old Sep 24, 2016 | 05:28 PM
brjr1's Avatar
That's my next route. Thanks
Old Sep 25, 2016 | 05:10 AM
Let us know how it works out,,,,again I just did a quick google search for "strut mount" and saw serveral choices/options.
If you are going to have to have the bushings replaced, if the car has age and miles on it and the struts have never been replaced....for the money/time/effort to replace those bushings, you might look into "loaded struts" and just replace the entire thing....strut, spring, bushings, mount.
Old Sep 25, 2016 | 09:44 AM
brjr1's Avatar
That's the same as a "quick strut"? I've looked at that before. That seems the only resort.
Old Sep 25, 2016 | 10:32 AM
Yea, they go by different names....that and I'm getting old and can't remember names.
The bushings can be bought....I'm just saying that one would need to remove the strut, mount and that to even get to them....so why not just replace the whole thing - again assuming they are old and probably getting worn.
Old Sep 26, 2016 | 07:06 AM
brjr1's Avatar
Most definitely. I bought the car new and can assure the struts haven't been replaced before. Mechanic guy swears it's the bushings and insulators between the subframe and frame but since I can't get any parts, that leads me to the struts.
Thanks a lot!!
