Sway bar recommendations
Old May 2, 2007 | 09:29 PM
qbcarnes
Default Sway bar recommendations
So my car now has Tein S-Tech springs, KYB GR2 shocks and an APR strut bar. I was wondering if anyone had any suggestions for sway bars? I've seen one's by Comptech, Neuspeed, and Suspension techniques. Any ideas? Thanks.
Old May 2, 2007 | 09:41 PM
sir_nasty's Avatar
Default RE: Sway bar recommendations
I've heard of people having good results with 19-20mm rear sway bars and the brands you listed are the ones I would suggest.... You may also consider that some of the 19mm Acura TL rear sway bars will fit onto the 2000 accords (I think...) so that may work for you as well
Old May 3, 2007 | 12:20 AM
otsb708's Avatar
Almost A Senior Member
I have the Neuspeed 19mm Rear Sway bar installed now and there a noticeable difference in the way the car handles just from that upgrade. I just ordered the 27mm Front from Neuspeed so I am hoping that is going to get rid of the huge body roll that my car has. There are a good amount of people on here that get the TL sway bar just like Sir_Nasty said. I am sure they notice the difference right away. I wonder if the TL front is any different than the Accord?
Old May 10, 2007 | 04:25 PM
Velocifero's Avatar
i would personally keep the stock EX front sway bar and add a TL type S (previous TL body style) rear bar. should be only $60, and by keeping the front stock, it will balance out the car more giving you more understeer while giving you more control, which is usually always the goal.
Old May 11, 2007 | 06:47 AM
bssmagik83's Avatar
Check out this link. it discusses several different options for sway bars front and rear
http://www.v6performance.net/forums/...ht=cls+swaybar
Old May 11, 2007 | 02:38 PM
trukid21's Avatar
just wondering if you know where i could get just the tie bars for my car(besides e-bay). i'm getting a front strut bar from cardomain but they do not have one for tie bars. would any of the acuras work with the 5th gen?
Old May 11, 2007 | 02:50 PM
poser_pilot6
I have only ever seen a rear tie bar for 90-97 Accords; you can find one here:
http://www.procarparts.com/store-det...=onlinestoreDB
They offer one that is ten dollars cheaper, but its out of stock, so I didnt include that link. Hope this helps.
Old May 11, 2007 | 09:52 PM
trukid21's Avatar
thanks Poser. thats a cool site, too bad they run out of that cheapertie bar. i'll keep checking them again and hopefully they would re-stock those tie bars again.
Old May 12, 2007 | 06:04 AM
Check out the Energy Suspensions web site, they make great performing products for the Honda Cars...
Old May 12, 2007 | 10:44 PM
trukid21's Avatar
i checked them out, but i did not see anything for tie bars,only bushing.anyway,thanks for the helpAng.
