sways
Old Aug 30, 2008 | 01:30 PM
logan's Avatar
Default RE: sways
would it be better to get a kit or just the rear if the front is too hard to install forget it
Old Aug 30, 2008 | 03:52 PM
otsb708's Avatar
Almost A Senior Member
Default RE: sways
The front is not that hard to install.....
Old Aug 31, 2008 | 01:00 AM
03Sleeper's Avatar
Default RE: sways
Meh, it involves removing more stuff. Rear was an easy-peasy installation...like an intake (but easier).
Old Sep 1, 2008 | 07:04 PM
logan's Avatar
Default RE: sways
lookin at an eibach kit 27mm front and 23mm rear i believe for 300$
Old Sep 1, 2008 | 10:00 PM
03Sleeper's Avatar
Default RE: sways
That's not bad. Front is not worth it because front confronts the oversteer issue...but seein we drive FWD cars....we don't need it.
Old Sep 2, 2008 | 12:35 AM
logan's Avatar
Default RE: sways
so just a rear would be better and i save money
Old Sep 2, 2008 | 08:24 AM
  #17
falkore24's Avatar
Default RE: sways
ORIGINAL: 03Sleeper
Increasing the strength of the rear more than the front helps with understeer, but let's not overlook the main function of an anti-sway bar ....... combatting sway ..... body roll on hard turns. A well designed set of bars will always offer better handling than a single one. My tC has worse understeer than an accord out of the box, but I still have a Hotchkis set of sway bars ...... to deal with the understeer issue, the front is about 40% stronger and the rear is about 360% stronger. The handling improvement was drastic.
Old Sep 2, 2008 | 10:34 PM
  #18
logan's Avatar
Default RE: sways
hmmm thanks for the info ill have to choose for myself either a kit or rear sway. probably a kit
Old Sep 3, 2008 | 08:49 AM
  #19
falkore24's Avatar
Default RE: sways
It kinda just depends on how hard you want the car to be able to handle. I go for max handling with acceptable comfort. What is acceptable to me might not be to you though.
Old Sep 4, 2008 | 04:58 PM
  #20
logan's Avatar
Default RE: sways
the eibach kit is 27mm front and 23mm rear hows that?
