TL Strut Bar for 6th Gen Review
Old May 31, 2007 | 08:25 AM
tkundert2's Avatar
Default TL Strut Bar for 6th Gen Review
I paid about $55 fora new TL (2000) strut bar and it fit easily on my Accord.Steering responds quicker now, though itundersteers just a bit more. Install time was about 30 min. Simple, cheap, bolt-on upgrade (my favorite kind).
Old May 31, 2007 | 03:28 PM
bssmagik83's Avatar
Almost A Senior Member
Default RE: TL Strut Bar for 6th Gen Review
what is the thickness of the TL bar? did you have to change bushings and brackets?
Old May 31, 2007 | 03:47 PM
tkundert2's Avatar
ORIGINAL: bssmagik83
I assume you are referring to the rear TL sway bar (per your sig)? It is 20mm and I did use new bushings and brackets.
52300-SEP-A11
SPRING, RR. STABILIZER
$32.08
$32.08
52306-SEP-A11
BUSH, RR. STABILIZER HOLDER (20MM)
$1.58
$3.16
52308-S3M-A00
HOLDER, STABILIZER BUSH
$0.82
$1.64
Subtotal
$36.88
Shipping Charge [Shipping Charge may vary with package size / weight]
$5.00
Handling Charge
$2.95
Sales Tax
$0.00
Total
$44.83
Old May 31, 2007 | 04:00 PM
bssmagik83's Avatar
yah the rear... I was thinking of the CL-S one, obviously. either way im not sure that 1mm will make a difference in terms of too much understeer with my current set-up. (sig.) plus i heard the 6th gen sways fit the 7th gen....but im not positive on that maybe it was something else i heard.....anyway I like the price of that one compared to the CL-S rear sway
Old Jun 1, 2007 | 10:35 AM
tkundert2's Avatar
The only fit problem I had was the little hook welded to the body for the muffler hanger rubbed the bar and clunked a bit. I greased it and now it is quiet. If it acts up again, I will try to bend the hook a bit so it will clear. I think it is only an issue because the TL bar is thicker (the 14mm stock bar didn't rub).
You have a 19mm bar now?
Old Jun 11, 2007 | 02:11 PM
octaviusprime's Avatar
the site where you bought this TL Strut Bar from?
Old Jun 11, 2007 | 03:12 PM
tkundert2's Avatar
ORIGINAL: octaviusprime
http://www.acuraoemparts.com/delray/jsp/home.jsp
Old Jun 11, 2007 | 10:45 PM
peter4jc's Avatar
I just ordered my sway bar and bushings/bushing holders. $45, and change. Thanks for the link.
All I can hope for now, is that the links come of cleanly and can be re-used.
Old Jun 12, 2007 | 09:38 AM
tkundert2's Avatar
ORIGINAL: peter4jc
Yeah, mine were a PITA to remove but I got them off and reused them. I live in TX now but bought the car new when I lived in NJ so the 5 or 6 years of road salt had fused them on pretty good. I would soak them good with WD-40 or liquid wrench. It is hard to get much leverage with an allen wrench at first, so I cheated a bit with some channel locks to get them started. Good luck.
street_racer7112
Sep 16, 2007 06:51 PM
accords own
Aug 15, 2007 01:01 AM
bssmagik83
May 30, 2007 07:00 AM
bigdog1428
Dec 19, 2006 09:07 AM
sekander007
Sep 22, 2005 12:03 PM
