What kind of suspension is best for drifting?
Old Oct 31, 2010 | 09:16 AM
purpleman's Avatar
that makes sense, i've learned by past experience that the cheap stuff doesn't cut it. Why adjustable coilovers?
Old Oct 31, 2010 | 07:30 PM
g22cd5's Avatar
Supper Moderator
well for one the coilovers you can adjust to the height you like it vs. springs after they settle that’s all you get. Also you want to get struts and springs that match. Full coilover sets ups are done like that. The springs mated with the struts so they are meant to work 2geather. For the price your better off with a full coilover set up also. By the time you buy good struts and springs your gonna be in the 500-600 price range. So why not get the real deal that is meant to work with each other?...the F&F type 1s for your gen accord are like 600bucks or so. Good price for a good street set up.
http://cgi.ebay.com/Function-and-For...item2eafbc8ca9
Old Oct 31, 2010 | 09:12 PM
ebarrera661's Avatar
Almost A Senior Member
^ go for teins. They are alot, but they work, very well! i have them on my 1991 celica, and the cornering went from good to holy crap good
Old Nov 1, 2010 | 12:17 PM
purpleman's Avatar
alright thanks guys! i cant wait till i get it all on there
Old Nov 1, 2010 | 01:09 PM
keep_hope_alive's Avatar
other things to consider:
twin tube vs. mono tube construction - mono is more expensive but less noisy - more reliable.
height adjustment - you don't want height adjustments to sacrifice suspension travel (at least be adjustable). compare how height is adjusted and how the damper and spring will behave at your desired height. obviously, you want to consider suspension travel so you don't bottom out or constantly ride on the bump stops.
when you lower you need to check camber - and adjusters are $150 each wheel. I found some K-Sport adjustable mono-tube coilovers with front camber adjustment built-in (helps justify the extra cost). add alignments into the budget as well.
Old Nov 1, 2010 | 11:03 PM
purpleman's Avatar
ok what i gathered from that makes sense. Now what do u mean by suspension travel?
Robcie
Jul 6, 2011 01:25 PM
vipjdm-Justin
Jan 12, 2011 12:13 AM
SKHEMR
May 26, 2008 12:53 PM
MikeIsSweet
Nov 19, 2007 07:04 AM
RoXeTTeMaN
Sep 8, 2006 02:59 AM
