2005 55 plate Accord Tourer
Old Feb 14, 2012 | 10:16 AM
Sherbet66's Avatar
Default 2005 55 plate Accord Tourer
Hi,
I currently have a compression kit in place of a spare tyre, which I'm happy with for a backup for day to day driving around town. I'm am however a little apprehensive about driving to France this year (from Glasgow), so I'm planning on buying a tyre for this trip only. The space savers seem expensive, cheapest I see would be £115 used from an on-line breaker.
If I went for a bog standard steel rim from a part worn place would;
1. This fit in the boot
2. Would i lose the entire under boot compartment
3. What size should i look for if this fitted
Thanks for any help in advance.
Dave
Old Feb 14, 2012 | 04:44 PM
Since our USA Accord is a different car, I can only suggest in general terms.
In the USA Accord, a full-size wheel-tire will fit, but no room for the little tool-kit thing. Plus I think it lifts the trunk-floor-board a few mm.
You could look for a narrower tire, so it would NOT go together with your other tires as you rotate your tires. It would be dedicated to use as a spare. Look for a wheel-tire from a 2007 Civic (give or take a couple years). The rim is narrower, the tire is narrower, but it should bolt up and be usable as a spare. With mis-matched sizes, I wouldn't take it to a racetrack with that tire installed... :-)
Old Feb 15, 2012 | 04:24 AM
Sherbet66's Avatar
Hi,
thanks Jim, that's exactly what i wanted to know, the spare would be for this trip only and not for general use, so a missmatch with the other rims would not really be a big issue.
Many thanks again.
dresdenron
Oct 7, 2011 09:06 PM
mattgod69
Oct 30, 2010 08:54 AM
jimcrosbie
Feb 17, 2009 09:02 AM
HME
Dec 20, 2008 07:00 AM
colin
Feb 29, 2008 04:20 PM
