2007 Accord EX 4-door offset question for new wheels
Old May 26, 2007 | 01:09 AM
hotrod22's Avatar
Default 2007 Accord EX 4-door offset question for new wheels
Hi! I am new on here and just had a few questions about some new wheels. I have a 2007 Accord EX 4-door w/16"x 6.5"factory alloys. I am looking at some 17"x 7"Nex-O NT-5 wheels with 215/50/17 Hankook tires. I have found that the factory wheel offset is 55mm, is this correct? If so, these new wheels having a 42mm offset will put my wheel/tire more to the outside by 19mm, does anyone know if this will be a problem with clearance or any kind of other issues? I am not looking to lower my Accord at any time, so that is a non-issue. Any input will be great!
Old May 26, 2007 | 11:50 PM
Velocifero's Avatar
Default RE: 2007 Accord EX 4-door offset question for new wheels
whats up hotrod. well do this: turn your tires to the extreme right or left and see how much clearance you have left under the fender. you should be fine, but if that doesnt help, sometimes the only way to know for sure is to try em for size
Old May 27, 2007 | 12:01 AM
Check to see if you also have the TPMS installed with this New Model Car ask your dealer if your not sure.
New 17 " wheel and tire package should be either a 17 x7" or 17 X 8" The ET on either wheel will be at 40mm with a 64.1 at the hub, tire sizes are 215/50/17 , keep your tires OD @ 25.0 to no more than 25.5 to keep it safe..
Old May 27, 2007 | 01:54 AM
hotrod22's Avatar
Thanks for the replies guys!It doesn't say anything on my window sticker(from the dealer) about having TPMS, nor did the salesperson mention it, so I'm pretty sure it doesn't.The stock tires have a 25.6" diameter and the new tires have a 25.4" diameter, so I should be good, right? Wheelmax.com has the package(look in the 1st post) for $918 shipped, sound like a good deal?
Old Apr 3, 2012 | 03:44 PM
srini-honda's Avatar
Does wheel offset of +45 with similar bolt pattern and center hub bore fit 2007 Honda accord EXL-V4., OEM rims come with +55 offset I think, I am worried if this 10mm difference in offset will have any issues with calipers or fenders or suspension or any other problems? Also I am using the same tires as OEM spec., 205/60 R16 91V
cardude
13
Dec 23, 2012 12:56 PM
Jason Friesz
Oct 18, 2012 09:16 AM
srini-honda
Apr 4, 2012 10:40 AM
TrIkKeDoUt
Oct 31, 2007 07:31 AM
magnod
Jan 23, 2006 03:32 PM
