2008 Accord Wheels Specs
Old Sep 26, 2007 | 11:14 AM
SPG
Default 2008 Accord Wheels Specs
Does any one know what the wheelSpecs on the 2008 Honda Accord are - Height, Width, Off Set - has any one done an up grade on there car ,yet if so what wheel did you go with and what sizes- ..
Thank you this wellhelp me so much .....
Old Sep 26, 2007 | 12:09 PM
smaglik's Avatar
Default RE: 2008 Accord Wheels Specs
Did you buy one?
smaglik's Avatar
Did you buy one?
Old Sep 26, 2007 | 12:36 PM
SPG
ORIGINAL: smaglik
Did you buy one?
No I wish,
Im tyring to do a wheel upgrade with some lipsfor a friend of mineand i dont have accsess to the car ....andI dont know the off set of the front and rears or ifI can do a stagarred set up ..and I dont want it to look like blaa..if any one has this info i would appricciate it ...
Old Sep 26, 2007 | 12:47 PM
smaglik's Avatar
Would a honda parts counter have it?
Old Sep 26, 2007 | 02:53 PM
Danny D's Avatar
check out this link. It has the specs for a 19 x 8 HFP wheel. Anyone know if this would work on a 2007 Accord? Dan
http://cgi.ebay.com/ebaymotors/ws/eB...82410&rd=1
Old Sep 26, 2007 | 03:39 PM
SPG
First thank you for the link - If the bolt circle is 5 x 114 and the hub is 64 on the wheel it should work the only thing is the OFF SET on a 2007 accord is 45 mm and these wheels are 55mm so the wheel will sit in 10 mm if that dosent bother you... Also if you have modification on your car such as upgraded brakes or if its lowered you may come across problems ..
Old Sep 26, 2007 | 03:53 PM
Danny D's Avatar
My 07 has the 17"(V6 6 speed)wheels with a 55mm offset. That being said, I am concerned about the overall diameter change of the wheels and tires over stock. Is the speedo electric and can it be recalibrated?
Old Sep 27, 2007 | 08:18 AM
SPG
IF you go to www.BBS-USA.com and go to the application guide and put in your car it says a
19 x 8 will work go check for your self ...
Old Sep 27, 2007 | 08:39 AM
smaglik's Avatar
i must admit, those rims do look nice.
cbondhonda
Jul 21, 2007 07:10 PM
savage99ss
Feb 23, 2007 05:44 PM
Jazzyguy
Sep 3, 2006 03:27 PM
AznMaNg282
Aug 23, 2006 09:30 AM
no_doz
Jun 11, 2006 08:08 PM
