2009 Accord EX-L V6 Alloy Rim
Old Jun 25, 2009 | 06:25 PM
mobstermobi
Default 2009 Accord EX-L V6 Alloy Rim
Hi, I was told by my dealership and several other dealership parts department that my 17" OEM alloy rim for the V6 is different from those of the EX-L four cylinders. Is that true?
My rim is damaged by a parking attendant and I have been looking for a replacement, but the new one is simply too expensive (466+7% tax).
Thank you for your attention!
Old Jun 25, 2009 | 07:59 PM
dgp1961's Avatar
Almost A Senior Member
Must be if different dealerships are telling you that. Do one of two things (or both) go to a lot and check the stickers on both different cars. Stickers will have the size most likely or look on line. This should not be too difficult to figure out. Also shop on line for that wheel, just Google it. You'll be sure to get hundreds of hits some most likely cheaper than the dealer.
Old Jun 26, 2009 | 07:31 AM
Looks the same to me...
Your EX-L V-6 has #2, 17x7.5 inch size.
The 4-cyl EX-L has the same wheel.
The 4-cyl LX has the #1 steel wheel with plastic wheel covers.
I'm not sure which version Accord has the #3 16-inch wheels??
Starting in 2003, the 4-cyl and V-6 Accords have the same bolting pattern. Even the Civic starting around 2006 has the same bolt pattern.
Besides that, many dealers will swap rims around as an "accessory" purchase when you buy a new car.
Old Jun 29, 2009 | 01:52 AM
Question
Hey there member...Does your rim look like this one I posted?
Let me know by P.M.
Old Jul 2, 2009 | 12:24 AM
mobstermobi
nope, it is a different one, the angular 7 spoke. Anyhow, there are 2 specifications I ran into for the rim, 17 x 7.5 and 17.5 x 6.5J, I am even more confused now.... which one does my V6 have!! >.< Thanks
Old Jul 2, 2009 | 06:51 AM
I have never seen a 17.5 inch rim. I bet that's a typo.
Old Jul 5, 2009 | 12:41 AM
mobstermobi
thanks for the reply.
Also, I am thinking about changing all my rims to
Alloy Wheel 18" RGR-16D HFP Painted Finish Alloy Wheels
the recommended tire size is 225/45R18 95Y XL, I was wondering since the O. E tire rating for the 17" is 93V, if other speed and load ratings will also suffice for the 18". I am considering Michelin Pilot Sports A/S Plus. Any thoughts and suggestions? Thanks
Old Jul 6, 2009 | 09:05 AM
From 93V to 95Y, you're good.
The "93" is the load rating, and you're going with a higher rating. You don't want to go lower.
The "V" is the speed rating, & Y is a higher-speed rating.
Old Jul 7, 2009 | 11:00 AM
mobstermobi
Thank you very much for the information!
Also, one of the dealership said that that optional wheel I posted earlier can be directly use to fit the 235/45R18 tires, which come as OE on accord coupe V6. I was wondering if that is possible since the recommended tire specification for this is 225/45R18? Won't the mismatching tire width cause problems? Thanks!
Old Jul 7, 2009 | 11:43 AM
That's just a bit larger (wider tread & slightly larger overall diameter). Overall diameter is about 1.4% larger, which influences your speedometer & odometer.
"Mismatching" the width would be a big problem if you were getting a couple tires. When you get all 4 the same, it's not the same kind of thing. If that size is available on some version of the Accord, then I bet it won't have a problem rubbing against the fenders or brakes.
atom1
Nov 15, 2010 01:56 AM
Sk8r776
Sep 1, 2009 05:03 PM
hoonhooon
Jan 7, 2008 06:47 PM
Honda_Dude
Jan 21, 2007 12:08 AM
KevinFelt
Mar 30, 2006 11:02 PM
