97 Accord- Finding the right rims
Old Apr 7, 2012 | 09:47 PM
crispin's Avatar
Originally Posted by RobinsonRicer
that answer helps quite a bit. however there is still the weight rating that baffles me. my car needs an 88, these are 84. You have the same car it seems, what do you have on yours?
I have no idea cause I have only concerned myself with weight ratings on my tow vehicles.
Right now I am running a set of Bridgestone tires in the stock size that I got from a junkyard for $100 for a set of 4 that still had the nubs on them when I bought them.
You are concerning yourself about the wrong thing. I have never ever heard of a passenger car blowing a tire because of improper tire weight rating. Unless you are towing or carrying unusual loads with your Honda you do not need to concern yourself with it.
Old Apr 8, 2012 | 06:59 AM
OP- Crispin is right. The difference in the load rating is not a concern....unless you are planning on pulling a horse trailer or something, are you planning on towing any kind of trailer?
Old Apr 8, 2012 | 06:36 PM
RobinsonRicer's Avatar
Ok. Well then what do you think about the rubbing sound when I brake if the tires are the same diameter and only 10mm wider than stock?
Old Apr 8, 2012 | 07:00 PM
crispin's Avatar
How come you do not want the answer?
What answer do you want?
You give me the answer you want to hear and I will write it for you.
In the mean time here is the actual answer...
Originally Posted by crispin
Your problem is this (and this is the answer, you do not need to look any further at all this is the answer)
You have offset issues on the wheels (they are too inboard or too outboard) and cause rubbing issues when you brake because they are rubbing somewhere. When you brake the front of your car dips down which puts the tires closer to the fender lips or inside wheelwells.
That was your answer, you do not need to explore weight capacities, rubber compounds, tread patterns or anything else.
Old Apr 8, 2012 | 08:06 PM
Oh I see, well perhaps I now need an answer to what will I do?
I'm not too familiar with tires. If they're offset- which I'm assuming by the rubbing- too inboard then should I just have them remounted?
Old Apr 8, 2012 | 09:44 PM
crispin's Avatar
The offset is part of the wheel. The offset has nothing to do with the tires.
It is a measurement of how far the....here let me let someone else explain it to you.
Wheel Tech - Offset
You may need spacers to run the wheels you have.
You need to measure the offset and post it here so we can see if it fits correctly.
Old Apr 8, 2012 | 11:51 PM
  #17
Oh, thank you, this makes more sense now. I will try that then.
Old Apr 20, 2012 | 07:18 PM
  #18
londonvaga's Avatar
Hi. I don't have an answer for your questions, but I'm here because I'm in the same situation. I NEED AN ADVICE!!! I just purchased on line a package with wheels(17x7 4-100/114) and tires(235x40R-17) for my accord 97 lx 4drs 4cyl. According to the web site(discount tire direct) and the seller, this sizes would fit perfectly my car without adding or removing any part of the car. Is this true?
PLEASE HELP ME.....
Old Apr 20, 2012 | 07:31 PM
  #19
235 seems pretty wide for an Accord, seems like you might have some rubbing when they are turned all the way. The widest I have run is 215. But what the offset of the rims is will play a factor in this.
Old Apr 20, 2012 | 10:59 PM
  #20
Talking Hi WheelBrokerAng Here
PLEASE HELP ME.....
Here is my information on this fit up...
On your car, the recommended size to go with is going to be 215/40/17"...even if you were going to an 18" tire and wheel combo...I would only be selling you a 215/40/18" pkg for your car..and that is for a 1990 thru 1997 Accord..
Attached Thumbnails 97 Accord- Finding the right rims-580199_10151466074965618_298621765617_23125251_152873002_n.jpg
