Brake pads and disks?
Old Oct 24, 2006 | 04:37 PM
camacho19
Default Brake pads and disks?
I just bought a 1996 Honda Accord EX, and it needed a brake job. I put new pads, but I forgot to add new disks.
Which ended with lots of squeaking noise. My question is... Can I wait like A week before I can add the new disks, "Without
having to replace the pads again"
I appreciate the help,
Thank you.
Old Oct 24, 2006 | 04:43 PM
sir_nasty's Avatar
Default RE: Brake pads and disks?
when you installed the pads did you put some anti squeek stuff on the back of them? Also, as long as the pads aren't grooved you should be fine to replace the rotors without doing the pads again
Old Oct 24, 2006 | 05:12 PM
camacho19
Thank you for the tip
Old Oct 24, 2006 | 09:02 PM
sir_nasty's Avatar
Not a problem! I hope it helps, that anti-squeek stuff is cheap and usually just spray can crap that goes in between the pads and the calipers
Old Oct 29, 2006 | 09:37 PM
deserthonda's Avatar
you might just need to resurface the rotors,, no need to replace and spend extra money if rotors are thick enough to resurface ..
and NO you DO NOT have to replace brake pads again
sach4u1
Oct 10, 2010 03:12 PM
cowsgonemadd3
May 12, 2010 01:48 AM
thunder_x
Nov 14, 2009 11:13 PM
J2Performance
Jan 15, 2008 04:29 PM
