Brakes
Old Oct 8, 2009 | 09:23 AM
honda4lifeMississippi
Default Brakes
My car needs brakes and I got a quote from some national brake guy. He said the car recommended ceramic brakes which is 50 more per axel. What is ceramic brakes and what the difference between those and regular brakes.
2004 LX 2.4I Auto
Old Oct 12, 2009 | 01:09 PM
searich07's Avatar
Ceramic pads were introduced in 1985 on a few new vehicles. Mass secondary market applications for ceramic-based disc brake pads are now becoming widely available
Installing ceramic pads on your original rotors will wear rotors out faster than if you stuck with semi-metallic pads. Dealers will sell you ceramic pads, but don't buy them unless rotors can handle them.
There may be poor stopping power with cold brakes. This is true about older ceramic pads or pads designed for racing. Rotors must be designed for ceramic pads, otherwise the rotors will typically wear faster. Check with your vehicle manufacturer
Ceramic pads still create dust, it is not black and cannot be seen. Current consumer grade ceramic pads have great stopping power. About 33% of new vehicles (domestic and foreign combined) today come stock with ceramic pads. Current generation of ceramic brake lining compounds contain no chopped steel fibers or steel wool as found in earlier semi-metallic linings, but instead substitute ceramic compounds and copper fibers. Some ceramic pad applications may also incorporate noise-reducing features such as chamfers, slots and insulator shims. Regards
Richard
Old Oct 13, 2009 | 09:03 AM
edbro
So, are there aftermarket rotors for the Accord that can handle ceramic? How do I identify those?
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
