Different tire size
Old Feb 23, 2011 | 12:43 AM
8lug's Avatar
Talking Different tire size
I have a 1993 accord. The OEM tire size is 195/60/15. I have 4 good 205/65/15. Will these tires fit ? And how far off would this effect my speedometer ?
Old Feb 23, 2011 | 07:06 AM
http://www.miata.net/garage/tirecalc.html
205/65-R15 is 32mm larger overall diameter & 10mm wider, so look at clearance. Especially clearance against the curved arm of the steering knuckle which curves around the inner sidewall towards the upper ball joint.
Your speedometer will read 5.3% low.
Old Feb 23, 2011 | 09:07 AM
8lug's Avatar
I have 205/60/15 on now with no problem. Is the middle number the height of the tire ? A 65 would really be close if so. At 5.3% lower on speed that would be about 57mph when my speedometer is reading 60 right ?
Old Feb 23, 2011 | 09:15 PM
205mm is the width of the tire, so I guess that doesn't rub on the knuckle.
The /60 or /65 is the section height. 205/60 height is 60% of 205 or 123mm tall. 205/65 height is 65% of 205mm or 133mm.
Speedometer error is the other way around. When your speedometer reads 60, you're really going 63.2mph.
Old Feb 24, 2011 | 02:08 AM
8lug's Avatar
Thank you Jim that clears it up. I'll just have to remember the speed differential.
davidle504
Jan 6, 2013 08:20 AM
kriegz99
Aug 11, 2007 08:41 AM
RTexasF
Jun 13, 2007 07:03 PM
dinzer
May 25, 2005 09:27 PM
DDTG_ACCORD
Apr 29, 2005 05:23 PM
