How to measure tires + rims diameter?
Old Jun 4, 2007 | 07:02 PM
AyashiFX55's Avatar
Default How to measure tires + rims diameter?
Hi guys! i'm pretty excited,i'm getting ready for new rims and tires !!! But the problem is, i don't know how to measure them. Would want them on a Accord 96 4dr , the rims are 17" and tires are 215/45/17 ... How do i measure the total surface and have the diameter,so i could check if they fit the hole there. .. THanks!! (Diameter of rims with tires on)
Old Jun 5, 2007 | 11:11 PM
Default RE: How to measure tires + rims diameter?
Hi Member...try to use the search engine above by putting in tire and wheel sizing..It works and there a pleanty of links in there to use
Old Jun 6, 2007 | 07:35 AM
BlkCurrantKord's Avatar
You're bolt pattern is 4x114.3 make sure the wheels you get have that bolt pattern. The tire size is fine for the 17" rims.
Old Jun 6, 2007 | 04:05 PM
AyashiFX55's Avatar
My stock bolt patterns are 114.3 ? Thanks!
petesbween
Oct 30, 2007 08:47 PM
Thumper26
Oct 11, 2007 05:32 PM
importnewbie
Aug 7, 2007 08:29 PM
thunder_x
Jul 13, 2007 04:20 PM
03Sleeper
Jun 30, 2007 12:49 PM
