offset for 05 accord lx
Old Sep 11, 2008 | 02:36 PM
lcc27
Default offset for 05 accord lx
Does anyone know the proper offset for a 05 accord lx v6? I am currently shopping around for tires/wheels package. I am probably gonna go up to 17's in tire size. I checked the usual suspects so far with tirerack and discount tires. I saw 2 sets at tirerack. Any other recommendationsfor a good sourcewith reasonable tire/wheel packages? Wanted to get it before winter as I am in need of new tires. Thanks in advance for any help!
Old Sep 11, 2008 | 02:55 PM
falkore24's Avatar
Default RE: offset for 05 accord lx
I think all stock honda wheels are 45 offset
Old Sep 11, 2008 | 09:33 PM
Falkore24 has the numbers correct for you , they are 42 to 55 mm...
[IMG]local://upfiles/22/7D84698C94FB459CAFF5C99D336D9837.jpg[/IMG]
Old Sep 12, 2008 | 08:51 AM
falkore24's Avatar
42 to 55 is the replacement range Angelo?
Old Sep 14, 2008 | 11:45 AM
lcc27
Thanks for the info! Also, I was thinking of going for 225/17s (tire size), what would be a good offset. Any suggestions?
Old Sep 15, 2008 | 10:13 AM
falkore24's Avatar
Tire size and offset are 2 different things and are not related. Offset should be chosen for 2 reasons: to not rub the car on turns and to achieve the outter surface appearance that you want (tucked or flush). Tire size should be chosen to minimize error on the speedometer unless you have another means for correction. Use the calculators in the wheels and tires sticky to figure out what you should buy.
Jason Friesz
Oct 18, 2012 09:16 AM
ochondakidd
Feb 21, 2012 08:06 AM
KEYZ
Apr 23, 2007 05:55 PM
GtownAccord
Feb 27, 2007 04:04 PM
STRIKER
Oct 6, 2006 07:15 AM
