Offset
Old Jan 17, 2014 | 10:25 AM
98EXV6's Avatar
Default Offset
Hate to beat the dead horse coz, this may have been discussed in the past but I cannot seem to find the thread but I have an 03 CRV with aftermarket 17 in rims. I want to give them to my son and as far as I know - they have the same bolt pattern and the number of bolts - my question is does both cars have the same backspacing or offset or at least close so we can just remove and replace so I can buy a new set for my CRV. Thx for the tip.
Old Jan 18, 2014 | 12:50 AM
1st thing we need to know is what vehicle is your sons make , year and model...
2ndly.. your CRV's bolt pattern is a 5 x 114.3 mm - The hub hole is 61.4 mm - the offset is between 35-45 mm - and your thread size is a 12x1.5 mm nut..
This should help you a little..
Old Jan 18, 2014 | 10:47 PM
98EXV6's Avatar
forgot to mention my son's ride. 02 Coupe EX-L A4
Old Jan 20, 2014 | 10:19 AM
For some reason I thought the 2002 Accord 4-cyl has 4-bolt wheels. Only the V-6 has 5-bolt pattern. Beginning in 2003 they all have 5-bolts.
If it wasn't for that, I bet they'd work.
Old Jan 24, 2014 | 05:28 AM
98EXV6's Avatar
It is a V6 - I think they have the same bolt pattern, just not sure about the offset or backspacing.
Old Jan 26, 2014 | 01:02 PM
hondafreak91c's Avatar
It should work. If its a universal 17in rim, you shouldh ave no clearnace issues. They are normally pretty conservatively sized. If anything, you may have to add a 3mm spacer to clear the brakes, but I doubt it would be needed.
You won't really know until you try it.
Old Feb 1, 2014 | 05:09 AM
98EXV6's Avatar
Thanks!
Old Feb 3, 2014 | 08:17 AM
I should've said that many wheels have the offset stamped somewhere on the backside of the wheel. Usually with the letters "ET" like ET41 for 41mm offset.
vintageant
Feb 1, 2007 02:14 AM
thunder_x
Nov 6, 2006 01:22 AM
STRIKER
Oct 6, 2006 07:15 AM
beauespirit
Apr 7, 2006 05:01 AM
magnod
Jan 23, 2006 03:32 PM
