Problems putting 2008 rims on an 2006?
Old Sep 3, 2009 | 01:17 AM
gocubsgo
Thumbs up Problems putting 2008 rims on an 2006?
I have an 06 accord with the 16" rims. I'd like to put 2008 17" on it. I've called my local Honda dealership, but they won't say for sure. The guy said they should fit but Honda doesn't recommend switching rims. Has anyone done this, and if so do you have any pics.
Old Sep 3, 2009 | 10:43 AM
New gen, but I don't believe Honda changed offset. It may be that the 8th-gen car has more fender clearance for WIDER tires. I don't know the specs.
You could go to tirerack.com & go thru the motions of picking rims for your car, then pretend you're buying for a 2008. If they both come up with the same choices of 17" rims. Especially if the choices for TIRE sizes are the same, then you're good.
Old Sep 3, 2009 | 01:50 PM
Talking Hi Member
Yes they will fit your car..
They both have a bolt pattern of 5x114.3mm the ET on both is 40mm and the hub on both wheels is at 64.1mm... Tire size for 17" 225/45/17
Attached Thumbnails Problems putting 2008 rims on an 2006?-wtcyahootoppicsemail2_small.jpg
Old Sep 5, 2009 | 10:29 AM
gocubsgo
Thumbs up
Thanks for the imput. I'll post some pics when I make the change.
Old Sep 5, 2009 | 06:01 PM
We will be happy to see how they look on your ride...
Attached Thumbnails Problems putting 2008 rims on an 2006?-wtcsept11wtcsouthtowerua175_small.jpg
Cody Is Cool
Jul 23, 2007 03:58 PM
vwl1980
May 21, 2007 07:45 PM
VanIsle
May 18, 2007 08:45 AM
ncsgoofy
Nov 28, 2006 09:50 PM
