Rim size 2006 Accord
Old Sep 12, 2013 | 03:10 PM
dctaz37's Avatar
Default Rim size 2006 Accord
I have a 2006 Accord with 16 rims. I have 4-15" winter tires I want to repurpose. When I am looking for rims what do I look for 15", 5 hole then ???
Old Sep 12, 2013 | 03:18 PM
shipo's Avatar
Per TireRack.com you need a set of 15x6.5 wheels (which should have a set of 205/65 R15 tires mounted on them) with a bolt pattern of 5-114, an offset of +45mm and a backspacing of 5.47".
What size are the tires you're trying to repurpose?
Old Sep 12, 2013 | 05:12 PM
IIRC, I used a set of 195/65 R15 snow tires on a 2003 Accord 4-cyl without any problem. Not the ideal size, but they worked. Should be the same for yours if it's 4-cyl.
I just tried TireRack, and for the V6 Accords they don't go smaller than 16" wheels. If you have a V-6 it might be that the brakes are bigger than the 4-cyl cars.
I'm going to move this over to the Wheel/Tire area.
Old Sep 16, 2013 | 01:39 PM
dctaz37's Avatar
The tires are 195 65 15 so they should be good. I put them beside the tires on the car and they are very close. I guess just a little bit narrower.
Old Sep 16, 2013 | 05:20 PM
Is your car a V-6? If so, make sure you find out whether the brakes are too big for 15" rims. That's my SUSPICION because TireRack listing for 15" snow package dissappears when I change the car to a 2006 V-6.
Old Sep 16, 2013 | 08:29 PM
dctaz37's Avatar
It is a 4.
Old Oct 1, 2013 | 03:45 PM
davedad's Avatar
I have 4 15" steel wheels off a 2006 Honda Accord VP, I am trying to sell all 4 for $150.00.
Old Oct 2, 2013 | 11:01 AM
dctaz37's Avatar
I bought 4 new rims and I'm good to go.
Tim
Jul 23, 2012 10:52 AM
jimmy
Jul 30, 2009 09:55 PM
94coupeaccord
Mar 3, 2007 11:17 AM
ThePappy
Apr 27, 2006 08:24 PM
dinzer
May 25, 2005 09:27 PM
