Smaller wheels for 06 V6 EX?
Old Feb 23, 2010 | 03:47 PM
ranck42's Avatar
Default Smaller wheels for 06 V6 EX?
I have an '06 EX V6 Accord Sedan. It came stock with 17" wheels, though some of the 4cyl models that year came with 16". Does anyone know if there is a problem fitting the 16" wheels to my car? TireRack.com only lists 17" (or larger) wheels as replacements, but I'd really prefer to move to a 16" if possible. I'd even trade someone my 17s for 16s if I was sure I would not run into a clearance problem with the calipers or something?
Old Feb 23, 2010 | 04:21 PM
I'm not sure, but here's how you can check...
Some on-line parts places use the actual Honda part number. Look up the brake calipers & the rotors. Same part #? Then you can swap.
Also... Go to TireRack & pretend you're buying a snow-tire package. See if a "-1" fitment is shown.
If neither of those helps, then your best bet is to find a friend with a 4-cyl (16" wheels) & do a trial swap.
Old Feb 23, 2010 | 04:37 PM
19Accord97
The V6 probably has bigger caliper and rotors.
Doesn't hurt to check though
Old Feb 24, 2010 | 11:11 AM
ranck42's Avatar
Thanks for that suggestion. TireRack does show a 16" option for snow tires, so seems like I should be able to swap stock 16s for my stock 17s. I'm sure somebody will want them. I'm fairly sure the V6 models have different calipers, but I can see them through the wheels and there seems to be plenty of clearance.
I'll start looking around locally for someone to swap with. Anyone near Blacksburg, Va. interested?
91exwagon
Aug 10, 2009 04:39 PM
Sweagle02
Feb 5, 2009 01:38 PM
cd75bus
Oct 27, 2008 02:41 PM
cd75bus
Oct 23, 2008 07:21 AM
starbai
Aug 27, 2008 08:26 PM
