speedometer
Old Feb 6, 2007 | 11:01 PM
wigandaccord90
Default speedometer
my tires are too small. the guy i bought it from put smaller tires on... section height. but anyways. is there anyway to adjust my speedometer?
Old Feb 6, 2007 | 11:04 PM
RTexasF's Avatar
Super Member
Default RE: speedometer
I doubt it but what car do you drive? No psychics here.
Old Feb 6, 2007 | 11:05 PM
wigandaccord90
1990 honda accord... i thought maybe there was some sort of sensor... the tires being too small, throws off the speedometer, odometer, and prolly cuts down on gas mileage
Old Feb 7, 2007 | 12:21 AM
poser_pilot6
How much smaller are they, overall diameter wise? If it isnt much, it shouldnt make much of a difference. With the tires being smaller, your speedo will read faster than you are really going, I do believe. I dont know that it will hurt your gas mileage much. Why dont you just go back to the correct size tire?
Old Feb 7, 2007 | 12:54 AM
RTexasF's Avatar
Super Member
Go here: http://www.dakota-truck.net/TIRECALC/tirecalc.html Click on "compare tire A to Tire B" Put the correct size in A and your current one in B. Scroll to the bottom to see speedo & odo readings.
Old Feb 10, 2007 | 04:05 PM
wigandaccord90
well i figured out that im usually going 5 slower than what im reading... and it gets bigger when i go faster... 70 is about 62... but the gas milage is horrible. i figure its because the engines got to spin faster to move the small tires. when im going about 60 the tach says 3500.. thats not good. so i guess ill be buying new tires
Old Feb 10, 2007 | 04:40 PM
poser_pilot6
Yeah, you definitely shouldnt be spinning 3500 at 60mph. I think Im at about 2200 or something when Im doing 60. I dont remember offhand.
What size tires does the car have right now?
Old Feb 17, 2007 | 02:56 AM
vansterdam
Here's a good tire size calculator to check what tire size you should be using instead.
Old Feb 17, 2007 | 10:08 PM
j_man_honda's Avatar
This is what me and my dad have done before.
-Remove the cluster.
-Take the clear cover off of the cluster (where u can touch the speedometer hand).
-Plug the cluster back in with the cover off.
-Follow a friend in another car down the road.
-Using cell phones get your friend to inform u when heis coasting at60mph.
-Following your friend closely, adjust your hand manually to 60mph.
-Put cluster back together.
It's sounds messed up, but it works.
Old Feb 18, 2007 | 05:14 PM
wigandaccord90
ahh i think ill just get new tires that are the correct size. the tires on there are 170/65 i think. they should be 185/70's. and i still have to figure out why i only get like... 12 mpg. this is getting off topic but does anyone know my gas tank capacity. i thought it was 17 gal. but i could be wrong. maybe my injectors are worn?
