tire and rim question
Old Jun 26, 2007 | 05:43 PM
sjg5359's Avatar
Default tire and rim question
Just got some new TL rims 17"replacing OEM 16" for 03 Accord LX V6.
Tire Size:
OEM 16"- 205/60/16
TL 17" - 235/45/17
Is there anything i need to do to be able to use these tires & rims. Change spedometer?
Old Jun 26, 2007 | 05:49 PM
sir_nasty's Avatar
Default RE: tire and rim question
I believe those tires are slightly larger in diameter than stock. That means your speedometer will be off by a little bit, just have someone get up to 60 mph and set their cruise then pace them and see how far off your speedometer is and make mental adjustments as you drive... you'll quickly get used to it.
Old Aug 12, 2007 | 04:36 PM
TL4U2DZYR
Has anyone else done this? I have an 06 TL and I am considering buying a 03-04 Accord EX as a third car... will the stock 235/45/17 tires fit on the Accord with no issues? I know it's wider than factory but I was wondering if anyone has done this?
Thanks in advance.
Old Aug 13, 2007 | 02:54 PM
PhotoJim's Avatar
Just as an aside, an easier way to check speedometer accuracy is to use a handheld GPS receiver. These receivers will tell you how fast you are going based on very accurate satellite readings instead of estimating forward progress by wheel diameter.
Old Aug 14, 2007 | 09:16 AM
RTexasF's Avatar
Super Member
This program has been used approximately times.
DML Tire and Wheel Calculator Results
Dimensions
Dimension
Tire A: 205/60 R 16
(26 x 8.07 x 16)
Tire B: 235/45 R 17
(25 x 9.25 x 17)
Difference
Width
Sidewall height
Overall height
Circumference
8.07"
(205.00mm)
4.84"
(123.00mm)
25.69"
(652.40mm)
80.69"
(2049.58mm)
9.25"
(235.00mm)
4.16"
(105.75mm)
25.33"
(643.30mm)
79.57"
(2020.99mm)
+1.18"
(+30.00mm)
-0.68"
(-17.25mm)
-0.36"
(-9.10mm)
-1.13"
(-28.59mm)
Speedometer Error
Actual Speed
Indicated Speed with Tire B
Speedometer Error
5 mph (8.04 kph)
5.07 mph (8.16 kph)
+0.07 mph (+0.11 kph)
10 mph (16.09 kph)
10.14 mph (16.32 kph)
+0.14 mph (+0.23 kph)
15 mph (24.13 kph)
15.21 mph (24.48 kph)
+0.21 mph (+0.34 kph)
20 mph (32.18 kph)
20.28 mph (32.64 kph)
+0.28 mph (+0.46 kph)
25 mph (40.23 kph)
25.35 mph (40.79 kph)
+0.35 mph (+0.57 kph)
30 mph (48.27 kph)
30.42 mph (48.95 kph)
+0.42 mph (+0.68 kph)
35 mph (56.31 kph)
35.50 mph (57.11 kph)
+0.50 mph (+0.80 kph)
40 mph (64.36 kph)
40.57 mph (65.27 kph)
+0.57 mph (+0.91 kph)
45 mph (72.41 kph)
45.64 mph (73.43 kph)
+0.64 mph (+1.02 kph)
50 mph (80.45 kph)
50.71 mph (81.59 kph)
+0.71 mph (+1.14 kph)
55 mph (88.50 kph)
55.78 mph (89.75 kph)
+0.78 mph (+1.25 kph)
60 mph (96.54 kph)
60.85 mph (97.91 kph)
+0.85 mph (+1.37 kph)
65 mph (104.58 kph)
65.92 mph (106.06 kph)
+0.92 mph (+1.48 kph)
70 mph (112.63 kph)
70.99 mph (114.22 kph)
+0.99 mph (+1.59 kph)
75 mph (120.67 kph)
76.06 mph (122.38 kph)
+1.06 mph (+1.71 kph)
80 mph (128.72 kph)
81.13 mph (130.54 kph)
+1.13 mph (+1.82 kph)
85 mph (136.76 kph)
86.20 mph (138.70 kph)
+1.20 mph (+1.93 kph)
90 mph (144.81 kph)
91.27 mph (146.86 kph)
+1.27 mph (+2.05 kph)
95 mph (152.85 kph)
96.34 mph (155.02 kph)
+1.34 mph (+2.16 kph)
100 mph (160.90 kph)
101.41 mph (163.18 kph)
+1.41 mph (+2.28 kph)
105 mph (168.94 kph)
106.49 mph (171.33 kph)
+1.49 mph (+2.39 kph)
110 mph (176.99 kph)
111.56 mph (179.49 kph)
+1.56 mph (+2.50 kph)
115 mph (185.03 kph)
116.63 mph (187.65 kph)
+1.63 mph (+2.62 kph)
120 mph (193.08 kph)
121.70 mph (195.81 kph)
+1.70 mph (+2.73 kph)
125 mph (201.12 kph)
126.77 mph (203.97 kph)
+1.77 mph (+2.85 kph)
130 mph (209.17 kph)
131.84 mph (212.13 kph)
+1.84 mph (+2.96 kph)
135 mph (217.22 kph)
136.91 mph (220.29 kph)
+1.91 mph (+3.07 kph)
140 mph (225.26 kph)
141.98 mph (228.45 kph)
+1.98 mph (+3.19 kph)
145 mph (233.31 kph)
147.05 mph (236.61 kph)
+2.05 mph (+3.30 kph)
150 mph (241.35 kph)
152.12 mph (244.76 kph)
+2.12 mph (+3.41 kph)
155 mph (249.40 kph)
157.19 mph (252.92 kph)
+2.19 mph<
Old Aug 19, 2007 | 09:00 PM
TL4U2DZYR
Wow, thanks for the detailed response. I did the swap and I think it looks awesome! The 17" TL wheels look great and they have not rubbed at all. What a difference a standard wheel that is very "normal" on the TL makes when placed on a 2003 Accord EX. I will post pics when I have a minute... I think it turned out great.
Thanksfor the info again.
Old Aug 20, 2007 | 10:57 AM
gamemaster000
I'm thinking about going this route for new wheels on my Accord. I'd love to see some pics to see how yours turned out. I've been trolling craigslist for the past week looking for a good deal on some wheels.
Old Aug 20, 2007 | 05:34 PM
TL4U2DZYR
So here are the pics: Like I said before 2003 EX-L with the 06 TL wheels.
235/45/17 Michelin Pilots
I like how it turned out...
Old Dec 24, 2007 | 12:54 AM
wheelman322's Avatar
I've been searching to see someone else who's done it. I didn't get mine on yet, but will post pics as soon as the wheels arrive. I'm really surprised this isn't a more popular mod....looks great.[sm=smiley32.gif]
Old Dec 28, 2007 | 10:46 AM
falkore24's Avatar
1 tip .... swap out the Acura center caps for Honda ones.
