Tires Rubbing
Old May 24, 2005 | 05:53 PM
Gummi_67's Avatar
Default Tires Rubbing
Hi Everyone,
I'm a newbie. I just got a 2004 Accord EX V6 Coupe. I'm upsizing from my stock 205/60/16s and after using the tire calculator have determined that 225/50 R 17 would be the best size. However, I can get a great deal on 235/50 R 17.... my question is - will tires that wide (235s) rub or cause any problems on this car without lowering or doing any suspension work????
Any helpmis appreciated.
Old May 24, 2005 | 06:37 PM
6thgen's Avatar
Default RE: Tires Rubbing
I doubt that you'll rub at stock height, but at 60mph you'll be between 1 to 2 mph faster than your speedo is reading. Not a big deal if your not a speed demon. I'd go with the correct size personally...only because no one can guarantee that it will or won't all cars are different. Two of the same models with the same wheels may have different problems with rubbing.
Old May 24, 2005 | 11:24 PM
Patrick's Avatar
i woudl think that the only issue is going to be the speedo, like 6thgen said.
Old May 26, 2005 | 10:53 PM
Gummi_67's Avatar
I actually decided to go with 225/50/17 which is the closest to my stock wheel size and since they are 10mm thinner i don't think i'll have a rubbing issue.
I'm getting Hankook Hankook Ventus HRII H405 Tires. Anyone have experience with them? For what I'm doing they should be more than fine. They're here if you wanna see them: http://www.1010tires.com/tire.asp?ti...ntus+HRII+H405
nafango2
Sep 29, 2007 04:02 AM
maro
Mar 10, 2007 12:15 AM
FlyLow
May 8, 2006 06:00 AM
hnic514
Apr 9, 2006 05:24 PM
bullet099
Oct 12, 2005 01:39 AM
