The Most Popular Examples of Performance Tires for Honda Accord
If you own a sports car like your Honda Accord, then you know how important it is to find the right set of performance tires. No other upgrade would be able to give you the grip you need and provide great acceleration, handling, and braking capabilities. Unlike regular tires, these tires provide a very high level of grip on dry tarmac, balanced dry/wet traction and handling, enhanced cornering and high-speed stability.
They feature durable and aggressive tread pattern, noise-reduction construction, and lightweight design. To make your shopping easier we've handpicked the most popular performance tire options for Honda Accord that are worth your time and money.
#1 Continental Extremecontact DWS06
https://www.carid.com/continental-ti...-84033809.html
Features:
- Improved tread life and fuel efficiency
- Extreme grip in sun, snow, and rain
- Enhanced performance in dry conditions
- Powerful wet handling and braking
#2 Pirelli P Zero
https://www.carid.com/pirelli-tires/...ro-467038.html
Features:
- Optimized tread pattern design enhances handling and control
- Unique grooves improve grip and roadholding
- Improved composite ensures maximum structural integrity
- Available in a wide range of sizes
#3 BFGoodrich G Force Comp 2
https://www.carid.com/bfgoodrich-tir...2-1248746.html
Features:
- Sport Design Tread delivers sharp steering response in wet and dry conditions
- Equal Tension Containment System maximizes the contact patch for better stability and wear resistance
- Dynamic Suspension System reinforced internal structure increases ride comfort
- g-Control sidewall inserts add sidewall stiffness to resist deflection for immediate turning response
#4 Bridgestone Potenza RE050A
https://www.carid.com/bridgestone-ti...-17797127.html
Features:
- Solid circumferential center rib for straight line stability
- Steel belt construction for added durability and puncture resistance
- Improved rolling resistance and increased fuel efficiency
- Circumferential grooves and special 3D blocks to avoid hydroplaning
When is it time to replace my tires?
Find out in our tech article! https://www.carid.com/articles/when-...-my-tires.html
carid
Aug 14, 2018 05:13 AM
ynctypes
Nov 29, 2008 09:27 PM
blacknight07644
Jul 5, 2008 08:33 PM
