Vendors Group And Special Buys Vendors and Advertisers will post special group buys for our members here!! Check it out.
Replace your worn-out tires with factory replacement and check the most common sizes!
Old Apr 17, 2020 | 09:25 AM
carid's Avatar
Former Sponsor
Default Replace your worn-out tires with factory replacement and check the most common sizes!
No matter how carefully you’ve driven your Honda Accord, sooner or later, you’re going to need new tires. Having the right tires is not only important for the health of your ride but also essential for your safety. The safest way to go is to choose the same size as your worn-out tires. This way you will not have any problems with the tire fitment or rubbing.
These tires provide optimal performance, ride comfort, and gas mileage. Sticking with a factory recommended tires means that you will maintain all these driving characteristics of your Honda Accord, and ensure its optimal performance in any driving conditions.
Below you will find a list of the most common replacement tires for Honda Accord.
Honda Accord 2008-2012
215 60r16 tires - https://www.carid.com/tires/215-60-r16/
225 50r17 - https://www.carid.com/tires/225-50-r17/
235 45r18 - https://www.carid.com/tires/235-45-r18/
Honda Accord 2013-2017
205 65r16 - https://www.carid.com/tires/205-65-r16/
215 55r17 - https://www.carid.com/tires/215-55-r17/
Honda Accord 2018-2020
235 40r19 - https://www.carid.com/tires/235-40-r19/
If you don't see the tire size that you run on your vehicle, view the full list of tires available for Honda Accord here: https://www.carid.com/honda-accord-tires/
WHEEL & TIRE SIZE CALCULATOR
Using our visual wheel & tire calculator you can also check other parameters of your tires, such as the sidewall height, width, etc., or view alternative options.
https://www.carid.com/tire-size-calculator.html
carid
Feb 27, 2020 07:23 AM
carid
Aug 14, 2018 05:13 AM
carid
Apr 14, 2016 07:08 AM
Mpwr
Jun 20, 2006 02:23 AM
OBv6shAWty00
Dec 10, 2004 10:17 PM
