93 Honda Clutch Problem
Old Aug 9, 2010 | 07:23 PM
tbeal11's Avatar
Default 93 Honda Clutch Problem
Hi i have a 93 honda accord in which the clutch goes to the floor and sticks to the floor so today i replaced the master cylinder which i found to be leaking so i got it back in and when i go to bleed it now it wont build pressure and i get no fluid at the bleeder so i opened the incoming pipe to the slave cylinder and i got fluid to pump out when i press the clutch so does this mean my slave cylinder is gone to? Thank you for any info
Old Aug 9, 2010 | 09:31 PM
This could be from air in the system.
I would reconnect the line to the slave and bleed air from that valve.
This is from Desert's DIY writeup on bleeding brake lines. It is basically the same procedure for the clutch master cylinder.
have an assistant pump the brake pedal slowly and evenly several times,,ask them to hold the pedal down, ,
loosen up the bleeder screw to let the air in the system escape, it is a good idea to put a hose from the bleeder screw going into a container , that way you do not splash brake fluid all over ,, while pedal is still down retighten the bleeder screw,, repeat it, till no more air comes out..
Remember not to let the reservoir go empty,, so it is a good idea to check and fill it after each wheel has been bled,,
Old Aug 9, 2010 | 09:46 PM
tbeal11's Avatar
i can't hold the clutch down cause it goes and sticks right to the floor i've had someone pump it by hand but i still got nothing at the bleeder when i cracked it. which i don't get how there was fluid at the inlet pipe on the slave cylinder when i pumped and not at the bleeder less than 1" away. that's why i think the slave is bad. is there any other reason that would cause the clutch to snap to the floor and stick? Thank you for that info it is appreciated
Old Aug 9, 2010 | 10:25 PM
When I changed out my master, I had the same problem at first whenever I have changed out part of my clutch hydraulics.
Pull up the clutch pedal with your hand at first. It should get better once all of the air has been pushed out.
If the pedal doesn't get better, then I would replace the slave as well.
Old Aug 10, 2010 | 03:43 AM
tbeal11's Avatar
Okay thank you very much
Old Aug 10, 2010 | 08:24 AM
Wrap a string around the clutch pedal so you can lift it while your foot is on it. Keep it under control, lift it smoothly. I've found that if you allow the pedal to SNAP upwards, that sucks air into the MC.
Old Sep 10, 2016 | 12:36 AM
Jjordan1680's Avatar
Default Clutch
Ok. I'm new everyone so bear with me please. I just got a 93 accord 5 speed. When I take off it does fine until I go to 3rd gear. Then I can put the throttle on the floor and all it does it raise the rpms and never gets faster. Does this mean I need a new clutch or what? I'm confused.
Old Sep 10, 2016 | 09:27 AM
Yes, clutch is slipping under load.
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
