2004 honda accord lx radio problem P0685
Old 10-07-2012, 04:54 PM
dukepethowesng's Avatar
Default 2004 honda accord lx radio problem P0685
I recently bought this 2004 honda accord lx, automatic transmission with 93,000 miles. The night i bought it, i found out that the radio lcd light is not working, the radio works fine and after a couple of days, the light comes on.
days later the radio itself stopped working and now it works whenever it wishes to work( coming on and off at it;s will)
I went to Auto Zone and the on board diagnostic check showed
TROUBLESHOOTING P0685
OEM BRAND: HONDA
DEFINITION
aaECM POWER CONTROL CIRCUIT MALFUNCTION
PROBABLE CAUSE
aa1: open or short circuit condition
aa2: failed ECM
Please what do I do because I an confused with this and the mechanics I have seen said I should take it to honda. sometimes the signal light makes strange noise when i turn it on when making either left or right turn and the harzard light, when turned on, takes sometime before it starts blinking.
please help me with ideas.
Old 10-10-2012, 01:02 PM
keep_hope_alive's Avatar
the factory radio has known issues. just replace with aftermarket (buy the harness and mounting kit that retains A/C controls)
Old 10-11-2012, 07:36 PM
thank you for the response. I have been considering this option, but today, I decided to remove the two battery terminal, check for corrosion and then fix it back. I did it and turned the car on the radio comes on and works perfect though the CD player does not work. After I turned the car off, I later turned it on and the radio won't work again. I removed the terminal and put it back and it work, but once I turn the car off and turn it on again, the radio won't work unless I remove the terminals again.
Do you think it is an electrical fault or power problem with the terminals?
Thank you for the first reply I appreciate.
Old 10-12-2012, 07:14 PM
just an internal problem with the factory head unit.
antoinelefebvre145
07-09-2013 09:35 PM
nashina1
06-02-2012 04:10 PM
maxdog
03-27-2012 03:45 PM
gray635
01-13-2012 07:34 AM
quinnow1
06-28-2011 01:46 PM
Quick Reply: 2004 honda accord lx radio problem P0685
