DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
2013 Accords - Front brakes squeal or scrape
Old 12-23-2012, 01:51 PM
Default 2013 Accords - Front brakes squeal or scrape
Honda has a technical service bulletin regarding this for the Accords.
Note: Technical service bulletins are not recalls, unless specifically noted as related to a recall; generally, they are to help Honda technicians with known issues. Issues noted in TSBs do not necessary apply to all vehicles. Normal warranty applies.
Honda TSB 12-081
Front Brakes Squeal or Scrape
SYMPTOM
While turning, a squealing or scraping noise is heard from the front brakes.
PROBABLE CAUSE
The disc brake pad retaining clip (retainer) shifted and is touching the rotor.
VEHICLES AFFECTED
2013 Accord – 2-Door L4 (Except LX)
From VIN 1HGCT1...DA000001 thru
1HGCT1...DA002001
2013 Accord – 2-Door V6 (Except LX)
From VIN 1HGCT2...DA000001 thru
1HGCT2...DA000937
2013 Accord – 4-Door L4 (Except LX)
From VIN 1HGCR2...DA000001 thru
1HGCR2...DA050377
2013 Accord – 4-Door V6 (Except LX)
From VIN 1HGCR3...DA000001 thru
1HGCR3...DA009828
CORRECTIVE ACTION
Center the retainer in the brake pad holder, and apply a thin coat of Molykote M77 to the edges of the brake pads where they contact the retainer.
sona1111
03-25-2013 07:36 PM
zoid_99
07-21-2011 05:14 PM
will93
03-17-2008 07:21 PM
91boz
01-01-2007 12:39 AM
ckebottle
09-23-2006 09:35 PM
Quick Reply: 2013 Accords - Front brakes squeal or scrape
