96 accord dies intermittently
Old 11-21-2016, 05:13 PM
Jaxlater's Avatar
Default 96 accord dies intermittently
I have a 96 Honda accord with the 2.2l. I had my check engine light on and had my codes read. They revealed I had a misfire in 1 and 3 cylinders and my ckp sensor was bad. I replaced the sensor and timing belt and water pump while I was in there and I put a new distributor cap plugs and wires. I was told by a local garage this was problem as well. The car still dies intermittently and there is a delay sometimes when the key is turned over to the time it actually turns over. When the car dies, my tach drops to zero but I still have power in the car. It is a manual transmission so it should show rpms if the clutch is not depressed. I'm not sure which direction to go now but my repairs haven't fixed the problem. Any ideas?
Old 11-22-2016, 10:20 AM
Loss of tach suggests either ignitor or coil. See following video for help in determining coil or ignitor.
Old 11-22-2016, 06:29 PM
Jaxlater's Avatar
Thank you for your advice. Replaced both icm and coil. Car is running great.
blkgolfer1
06-10-2013 04:45 AM
brakea
09-11-2012 10:37 AM
Nicolai Hobbs
07-12-2012 05:44 PM
rajateli
11-29-2010 05:56 PM
Paints Like Bob Ross
02-24-2009 06:22 AM
Quick Reply: 96 accord dies intermittently
