power steering pressure line
Old 11-02-2010, 02:42 PM
g22cd5's Avatar
Supper Moderator
Arrow power steering pressure line
I'm workin on deleting all my pluming on my power steering and I知 at the pressure line. Now there is a sensor that I知 99.9% sure controls how the p/s pump works. But if I remove it will I pop cel? I plan on looping all my lines like your suposta when you do a p/s delete but I was little confused about the sensor. Since I won稚 have the pump is will be useless??...I'm assuming. Also does anyone have a diagram of for a 93 cb power steering lines. I think I have 3 total but I知 little unsure on which ones I need to loop.
Old 11-03-2010, 02:22 PM
I'm pretty sure that sensor goes into the ECU for idle control. When you're cranking the steering wheel while NOT moving, the accessory load from the PS would otherwise screw up the idle. Since it's not directly emmissions-related, I bet a '93 does not have a CEL for that.
eduard
05-09-2013 12:11 AM
Genhero
11-08-2011 03:46 AM
svleonard
10-22-2011 09:53 PM
dadkind
12-31-2010 08:31 PM
navyzeke
10-07-2009 10:19 PM
Quick Reply: power steering pressure line
