power steering pressure line
Old Nov 2, 2010 | 02:42 PM
g22cd5's Avatar
Supper Moderator
Arrow power steering pressure line
I'm workin on deleting all my pluming on my power steering and I’m at the pressure line. Now there is a sensor that I’m 99.9% sure controls how the p/s pump works. But if I remove it will I pop cel? I plan on looping all my lines like your suposta when you do a p/s delete but I was little confused about the sensor. Since I won’t have the pump is will be useless??...I'm assuming. Also does anyone have a diagram of for a 93 cb power steering lines. I think I have 3 total but I’m little unsure on which ones I need to loop.
Old Nov 3, 2010 | 02:22 PM
I'm pretty sure that sensor goes into the ECU for idle control. When you're cranking the steering wheel while NOT moving, the accessory load from the PS would otherwise screw up the idle. Since it's not directly emmissions-related, I bet a '93 does not have a CEL for that.
eduard
May 9, 2013 12:11 AM
Genhero
Nov 8, 2011 03:46 AM
svleonard
Oct 22, 2011 09:53 PM
dadkind
Dec 31, 2010 08:31 PM
navyzeke
Oct 7, 2009 10:19 PM
