Sponsored by:
Sponsored by:
Brake lights won't go off
Old 05-05-2007, 05:01 PM
jrparks
Default Brake lights won't go off
Hey guys and gals, I've got a '93 Accord and I've discovered that my brake lights stay on all the time. -Even when the car is turned off. Anybody know how I could fix this???
Thanks
JR
Old 05-05-2007, 07:01 PM
Default RE: Brake lights won't go off
The brake light switch is stuck in open (non-extended position). When you press the brake pedal a spring in the switch is supposed to move the switch to closed position. I fixed the same problemon my 97 Acura TL by spraying the switch liberally w/ WD40. A good thing, since I couldn't see how to access the switch to replace. Hopefully your's will yield to this simple remedy.
Old 05-05-2007, 10:05 PM
Chiovnidca's Avatar
Is the switch properly adjusted?
Old 05-06-2007, 01:30 AM
Those switches have been known to break.
Or... Look for a missing bumper of sorts that's attached to the pedal arm & it's supposed to push in the switch when the pedal is not pressed down.
Old 05-07-2007, 10:23 PM
jrparks
Well, seems it was the bumper that broke. Thank goodness. I felt something hit my toe the first day the lights wouldn't go off, and when I looked under my seat there were a couple pieces of blue plastic that I assume were attached to the pedal arm. I wedged my keys between the brake light switch and the pedal arm and the lights went off.
Thanks for the input!
Old 08-21-2017, 09:53 AM
I just had the same problem...
Thank goodness my wife saw the lights on if not this morning it was going to be a dead battery and late to work!
I read this post and sure enough I found the plastic switch in pieces on the floor mat.
Now I know what to do.
Thank you guys for all this great posts!
kennilope
07-15-2022 12:21 AM
JohnnyQ
10-03-2012 11:54 AM
MikeT
08-31-2012 10:59 AM
boksh928
10-21-2009 11:55 AM
Quick Reply: Brake lights won't go off
