1997 accord heater and controls won't shut off even when ignition is off
Old Mar 9, 2013 | 03:53 PM
tomd's Avatar
Default 1997 accord heater and controls won't shut off even when ignition is off
I have pulled the #8 fuse and have removed the blower motor relay. With the #8 fuse pulled I can still turn on the fan and the heater controls still have power to them. With the motor relay pulled I still have power to my controls but the fan does not run. Any ideas?
Old Mar 9, 2013 | 05:11 PM
I'm going to move this
Old Mar 9, 2013 | 06:35 PM
Fuse 8 powers the mode control motor which selects vents, not the blower motor. Blower is powered through fuse 17 (under hood).
If you have power to the heater controls, w/ ignition switch off, the problem is likely a faulty ignition switch (a common problem on Hondas). You could check for power to fuse 8 contacts w/ fuse removed to confirm that switch is not disabling power when off.
Blower is always hot (ignition off or on) and enabled through fuse 8 providing power to the blower relay. Blower is enabled by blower speed setting switch. You should be able to disable blower, even if ignition switch is providing power when off.
emerald
May 25, 2020 05:14 PM
mmckinney11
Dec 18, 2012 11:24 AM
WI2003Accord
Jan 19, 2012 07:27 PM
Dan Fulmer
Nov 6, 2011 12:34 PM
live2rice
Apr 18, 2007 09:27 PM
