brake lamp indicator won't go off
Old Oct 19, 2009 | 10:45 AM
boksh928
Default brake lamp indicator won't go off
Hi
I have a 1998 Honda Accord with 150K mileage. Recently the brake lamp indicator in the dashboard went on. I replaced the blown out high mount brake light with the same part number and rating. But after 3/4 drives the indicator isn't still going off. What should I do next?
Thanks in advance.
Old Oct 19, 2009 | 01:09 PM
Check all the other lamps back there. That warning is triggered by uneven watteage from one side to the other. It may be that one side brake-light bulb is getting old or corroded or ??? Occasionally people have to put all new bulbs in just so they all match each other properly.
Old Oct 21, 2009 | 11:55 AM
boksh928
Hi Jim
Thanks for your prompt help. Yes I checked through the other lights and found one of them to be blown. So I replaced it, and the indicator immediately went off. Thank you very much.
peckd9274
Sep 11, 2012 05:08 PM
MikeT
Aug 31, 2012 10:59 AM
Mott23
Dec 14, 2009 08:48 AM
Uber
Dec 19, 2007 02:34 PM
djsinister
Mar 1, 2006 03:11 AM
