2005 honda accord dx hvac diagnostic
Old Jan 15, 2011 | 03:18 PM
shanefish247's Avatar
Default 2005 honda accord dx hvac diagnostic
The defrost and heat vent controls aren't working. I ran the diagnostic and the recirc blinks 4 times. Does anyone know what that code means?
Old Jan 15, 2011 | 04:28 PM
The HVAC DTC 4 is an open or short in the mode control motor circuit.
Check the No. 30 (7.5A) fuse in the under dash fuse relay box. It may turn out to be the motor.
If it is the motor, it is behind the glove box area. You would remove the glove box first, then pull the relays away from the bracket to be able to access the motor. See images.
Attached Thumbnails 2005 honda accord dx hvac diagnostic-remove-relays-bracket-behind-glove-box.jpg   2005 honda accord dx hvac diagnostic-mode-mix-motor.jpg
fcmoozin
Jul 25, 2012 07:15 PM
brahmabull
Jul 25, 2012 12:49 PM
Nathan Rowe
Apr 20, 2012 07:42 AM
WINSTON1425
Nov 9, 2009 02:25 PM
jason0595
Jul 25, 2009 09:49 PM
