Sponsored by:
Sponsored by:
94 Civic 4 cyl. engine noise
Old 08-14-2010, 03:10 PM
Wheelman's Avatar
Default 94 Civic 4 cyl. engine noise
94 Accord EX 4 cyl. engine noise
I was told that the timing belt(s) were replaced; no mention of the tensioner pulleys. No other accy's were replaced at that time. The noise is comparable to the sound of a vacuum leak; but it IS in the belts- specifically the timing.
If I have posted this in the wrong place; could an Admin please suggest where instead of just throwing it away please?
Thank you
Old 08-14-2010, 05:02 PM
This is the proper forum for your question.
How many miles are on your engine?
You should make sure that the P.S. and serpentine belts are not the source of the noise. If spraying belt dressing quiets the noise, then you will have to adjust the tension on the belt that stopped making the noise.
Old 08-15-2010, 06:03 AM
Wheelman's Avatar
Ok... thank you! That makes sense. The car has 145,000 on it. I'll try the belt dressing and see what changes.
Thanks again!
Old 08-15-2010, 08:29 PM
If the external belts are old, they might be hard & slippery. OVERtightening them (to stop the slipping) can lead to bearing failures.
creeve4
12-13-2012 06:59 PM
JimTrail
08-26-2012 08:13 PM
Wheelman
08-14-2010 07:36 PM
weekendwrench
10-18-2008 07:16 PM
mrmatrix
08-12-2006 05:39 PM
Quick Reply: 94 Civic 4 cyl. engine noise
