Sponsored by:
Sponsored by:
92 accord lx transmission problems
Old 04-30-2010, 10:21 PM
frankies31's Avatar
Angry 92 accord lx transmission problems
I am having some really wierd issues with my tranny. I will start out driving and about 3 to 5 minutes in to it the tranny will stop pulling all together. I can then put it into neutral and turn the car off for about 10 seconds and then restart it and put it back into gear and it will start pulling again for a few more minutes and then repeats the same process over and over again. I have completely rebuilt the tranny with all new steals and clutches and seals and i am still having the same problems. I have also noticed that the D4 light is flashing all the time. Could someone please advise me on what im doing wrong or what i should be doing to correct this problem. I bought the car for my 16 y/o daughter to go to work and this is just pissing me off now cuz she is having to drive my wife's truck and i want her out of it. Please someone help me.
Old 04-30-2010, 11:25 PM
The D4 light flashing means the transmission computer detected a problem and stored a code specific to that problem. You need to get that code and post it on here. Then we can give you more detailed instructions.
To get the code, get a thin paperclip or piece of wire and short a blue two-pin connector behind the passenger kick panel. Turn the key to the II position, and count the D4 light flashes. A long blink =10 and a short blink=1, so L SSS =13.
You might as well count the check engine light too if it starts flashing codes. That would tell you if the engine computer detected a problem.
See this site that has some pics. http://www.techautorepairs.com/dtc.html
Old 05-01-2010, 12:41 AM
hondadude's Avatar
What was the original reason for the trans to be rebuilt?
Did you install a new torque Converter?
Old 05-01-2010, 10:31 AM
frankies31's Avatar
Angry 92 accord lx
The reason that i rebuilt the tranny is because a local shop supposedly checked it out and stated that they found alot of particles appearing to part of the clutches in the fluid and recommended that it be rebuilt or replaced so i just rebuilt it but when i pulled it apart there was no debris in it at only a 1/4 of a teaspoon of shavings around the magnet and that was it. I rebuilt it and it is still doing the same thing that it was doing before i did that. Then i learned of this site and learned about the TCU and was very upset that the local shop did not know anything about this. I have it at another transmission shop this morning and hopefully they will know what to do but i just wanted to know what i could possibly check myself to try and fix this problem so my daughter can drive her car and not mine. Please advise me of any suggestions. Thank You, Frankie And no i did not install a new torque converter at all it was all good and by the way when i rebuilt it all the clutches and insides all looked good but i replaced everything anyway.
Last edited by frankies31; 05-01-2010 at 10:32 AM. Reason: forgot some information
Old 05-01-2010, 10:56 AM
g22cd5's Avatar
Supper Moderator
That sound like what happened to my tranny. Check your codes like said ^^^^ then post them up. Mine ended up being shift/tq. solenoid
aandc2005
11-15-2008 02:32 PM
a553487
10-27-2007 02:35 AM
postred
07-11-2007 12:35 PM
KimberlyC
04-16-2006 11:51 AM
monroe
10-24-2005 10:22 AM
Quick Reply: 92 accord lx transmission problems
