Sponsored by:
Sponsored by:
95 accord - fan problem
Old 07-21-2009, 03:00 PM
ddoublebb
Default 95 accord - fan problem
hello, I just bought a '95 accord...love it.except a week after the in dash fan became intermittent then quit all together. fuses are all good. couldn't find a relay that specified that fan. any ideas that don't involve taking out the dash board? thanks for any help. bb
Old 07-21-2009, 04:05 PM
00AccordLX5spd's Avatar
Registered User
I moved your thread to the General Tech help section. it will likely get more traffic there. I also added "fan problem" to your title so people can see what the thread is about and might click on it if they know how to help.
I can't say I am familiar with the part you are talking about, but I can tell you there is a link to a free downloadable shop manual for a 94 Accord (should be same as yours if you have a 4cyl) in the DIY section. If you want to take a look at it.
Old 07-21-2009, 04:11 PM
deserthonda's Avatar
if you are talking about the blower motor ( no air from dash vents) , there is a write up on how to diagnose that issue on the DIY section ... most likely you need a blower motor ,,smack the motor at the bottom and see if it turns on ,,if it does motor is junk.........if it does not ,, could still be a bad motor but first you need to chk for power and ground at the motor connector .. if you got both ( bad motor ) key on when you do the testing
CDJDM07
08-24-2011 09:51 AM
BOBBY-25
06-05-2011 02:40 PM
ramachan9
07-11-2009 11:57 PM
Equalizer
02-20-2007 08:57 PM
daddy
02-06-2006 02:52 AM
Quick Reply: 95 accord - fan problem
