Sponsored by:
Sponsored by:
97 accord 5sp. manual transmission problems
Old 03-10-2015, 11:26 PM
davntaz's Avatar
Default 97 accord 5sp. manual transmission problems
Hello I'm New here,
I have a 97 accord 2dr. EX coupe 2.2 while driving 50-60 mph. it was popping out of 5th gear,(thought it might be synchronizer not holding it in gear) but 25-30 miles later I was turning around & it stuck in gear, I was able to push clutch in & move it, but if I put shifter in neutral n tried to push it it acted like it was stuck in a higher gear (could move it & feel motor turning over). So I purchased another 5sp. tranny off CL (guy guaranteed it, but his PH is disconnected, so I'm screwed now) but Idid install a clutch kit & put back together & it wasn't 3-4 days later & it started doing about the same thing. I got it home & pulled it in garage. Now it's jacked it up & I start it w/clutch pushed in, I let it out still in neutral & the wheels turn, in neutral. I put it in 1st. (or any gear) & I let out on the clutch & it stalls like it's in a higher gear & brakes are locked up tranny makes a clattering noise, so I assume it has internal problems. I was driving-doing 20-30 miles an hour when it happened last time. So now I'm needing another 5sp. manual tranny that'll bolt up to a 97 2.2 accord EX or get the 1st. one looked at to possibly rebuild it. BTW I'm in the Nashville TN. area. If anyone has any thoughts, please message me.
God Bless U & Urs
David Kreitz aka DavnTaz
Old 04-11-2015, 01:06 AM
I moved this post of your's up here from the wanted section..It will work better for you up in this forum..
Old 04-11-2015, 09:10 PM
davntaz's Avatar
Smile RE: the problems I was having w/5 sp. tranny
First off I'd like o thank "WheelBrokerAng" who was kind enough to place my post where it was suppose to be.
As far as the problem I was having, I was able to purchase another tranny ($150) & had it installed for another $250 & was back up n running the next day.
Thanks to Skyler for his help, his shop is Sky mechanics in Old Hickory Tn. (615) 853-4141, if you need to ask him a question feel free to call him
Thanks for your help.
PS: on the roadf again
vetski179
08-19-2015 08:32 PM
tr0910
05-01-2014 04:05 PM
Speed1gt
11-11-2013 11:21 PM
j894
04-18-2013 05:59 PM
az4438
10-28-2011 08:30 PM
Quick Reply: 97 accord 5sp. manual transmission problems
