91 5sp transmission on a 95 accord? Help
Old Nov 11, 2013 | 01:16 AM
Speed1gt's Avatar
Default 91 5sp transmission on a 95 accord? Help
I have a 91 5sp transmission that I'm using for my auto to manual swap for my 95 lx coupe. So my question is can I use this transmission for the conversion. Thanks
Old Nov 11, 2013 | 05:59 AM
Yes......I'll assume the 95 is a 4 cyl
Old Nov 11, 2013 | 09:52 AM
g22cd5's Avatar
Supper Moderator
yes you can with should have no prob. If I remember correctly you will need a trans mount from explicitspeedperformance.net/
Old Nov 11, 2013 | 02:57 PM
Speed1gt's Avatar
Cool thanks guys. Have other questions. So are the 90 to 95 transmissions the same from lx. The 5 speed manual ones. thanks
Old Nov 11, 2013 | 06:19 PM
Any manual trans from 90 thru 97 F series engine, maybe even the 98-02 - can't remember and too lazy to look it up, will work. Also the ones that came off a H motor (prelude's) will work as well. There are "slight" gear ratio differences between them but they will bolt up and work fine.
Old Nov 11, 2013 | 06:21 PM
OP, sorry for this.......There is someone I haven't seen in a while....."G", hope things are going good for you. You still in AL?
Old Nov 11, 2013 | 08:20 PM
Speed1gt's Avatar
Cool. Well damn good info. so is their alot of wiring to be changed from the ecu harness to the motor harness.
Old Nov 11, 2013 | 11:21 PM
g22cd5's Avatar
Supper Moderator
search cb7tuner.com and yu will find a DIY on auto to 5speed swaps.
davntaz
Apr 11, 2015 09:10 PM
piggylover1985
Jun 7, 2011 09:01 PM
SkyhawkCaptain
Apr 21, 2011 03:53 PM
6hhhh6
May 31, 2010 01:27 PM
drocca0002
Aug 20, 2009 05:35 PM
