Sponsored by:
Sponsored by:
94 Accord EX overheating.
Old 11-25-2010, 04:13 AM
ajaybali's Avatar
Default 94 Accord EX overheating.
Have a 94 accord EX 5 speed. After about 40 miles it will start getting hot. The resevoir will have coolant coming from the cap. I will lose about 50 ounces of coolant. I have no visible water leaking in engine compartment, or white smoke from exhaust. I have flushed the Radiator, removed the thermostat, replaced the radiator cap, and added Block/radiator seal. There is no water in engine oil. When I bought the car was told Radiator was replaced. What else can I do pinpoint problem? I am thinking it is a Head gasket. Help.
Old 11-25-2010, 07:53 AM
Have you pressure tested the cooling system? Do the rad fans cycle on and off. Did you bleed the air from the cooling system.
Joshporsche
06-14-2006 10:07 PM
Rizzie
05-28-2006 12:04 AM
copa708
04-24-2006 08:36 PM
mennerja
01-06-2006 10:03 PM
erikhaha
11-20-2005 02:48 AM
Quick Reply: 94 Accord EX overheating.
