94 Accord EX overheating.
Old Nov 25, 2010 | 04:13 AM
ajaybali's Avatar
Default 94 Accord EX overheating.
Have a 94 accord EX 5 speed. After about 40 miles it will start getting hot. The resevoir will have coolant coming from the cap. I will lose about 50 ounces of coolant. I have no visible water leaking in engine compartment, or white smoke from exhaust. I have flushed the Radiator, removed the thermostat, replaced the radiator cap, and added Block/radiator seal. There is no water in engine oil. When I bought the car was told Radiator was replaced. What else can I do pinpoint problem? I am thinking it is a Head gasket. Help.
Old Nov 25, 2010 | 07:53 AM
Have you pressure tested the cooling system? Do the rad fans cycle on and off. Did you bleed the air from the cooling system.
Joshporsche
Jun 14, 2006 10:07 PM
Rizzie
May 28, 2006 12:04 AM
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
