Sponsored by:
Sponsored by:
Disconnected car battery to reset check engine light; now it won't even try to start
Old 05-24-2009, 04:02 PM
elderfoster
Default Disconnected car battery to reset check engine light; now it won't even try to start
I have a 1996 4cylinder Honda Accord LX. I've had it for 5 months without any problems, has had full maintenance once I got it without finding any problems.
I drove to San Francisco & the little yellow check engine light came on while I was driving up and down very steep hills. The engine sounded like it was struggling. I checked the oil and the oil was low and the oil dip stick had burned oil on the stick.
I added 1qt of oil and some gas, and then drove about 1hr to San Jose. In the morning, I checked the oil and it was below the minimum mark, but I still saw a bit of oil on the tip of the dipstick.
Now I added 1 more quart of 10W30 (instead of 5W30 because someone at Kragen's Auto told me if it is burning oil to use 10W30). The oil is full now but the light stays on.
Upon recommendation from a friend, I completely disconnected the car battery and turned on the interior lights to drain any left over electricity in the system. Then I reconnected the battery and tried to start the car - hoping that the check enigne light might reset, potentially indicating the car is okay.
However when I try to start the car, absolutely nothing happens. I turn the key and the lights come on, but the engine doesn't even try to start.
I haven't tested the battery, but it's a 5month old DieHard Gold and I'm pretty sure the battery is okay.
From what I've read on different websites, It may be interference with my anti-theft deterrent system. I read how it may think that someone is trying to steal the car so it won't let you start the car.
This is what I've managed to find out so far. Any suggestions on what I should do? Thanks.
Old 05-24-2009, 04:03 PM
elderfoster
The terminals to the battery have been cleaned and are firmly connected in the write position.
Old 05-24-2009, 04:39 PM
Hondas didn't come with an anti-theft device from the factory. Does your car have an aftermarket one installed?
If so, then you will have to figure out how to reset it.
Old 05-24-2009, 04:58 PM
elderfoster
I bought the car used so i guess it has an after-market anti-theft device (there's a red flashy light under the left of the steering wheel). I went outside and pushed my remote access buttons to lock/unlock/lock/unlock the car doors and I heard a beeping noise that I've never heard before.
After that the car started just fine and the check engine light is not on. I only idled the engine for a bit and parked it on the street. In a bit I will drive it across town and hopefully the check engine light stays off.
Thanks for the tip it worked!
Old 05-24-2009, 07:37 PM
Thanks for reporting back.
If the check engine light comes on, you should stop by an autozone and have them read the code(s). Report them here. They will be P####.
It is unlikely that you solved the problem with adding oil, so your check engine light may return. That error code will help identify the problem.
Old 05-25-2009, 02:44 AM
elderfoster
Well I drove the car about 25-30 miles today on the highway and off the highway. The light hasn't come back on yet. I'll let you guys know if it does.
bjr001
10-07-2014 09:29 PM
HateThisHonda
08-21-2013 09:22 PM
dawgfn78
04-23-2012 03:10 PM
hack
07-12-2011 06:12 PM
Quick Reply: Disconnected car battery to reset check engine light; now it won't even try to start
