Sponsored by:
Sponsored by:
Low fuel pressure, part deux
Old 08-12-2007, 10:20 AM
draser's Avatar
Default Low fuel pressure, part deux
Well, I'm back to square 1 with my fuel pressure, '99 Accord EX, 2.3 VTEC - super stock. I measure 32psi regulated, and 38 un-regulated. Book calls for 38-46 reg, and 47-54 unreg. On previous post I had the pump removed, screen looked clean. Gumout'ed screen and that plastic canister that holds it all together, pressure went up some. Good thing there's no real fuel filter to blame...
Of course the P 0171/P0170 are up. Done some work under the car this weekend, the fuel lines look good as far as kinks/obturations that one can see.
This time I partially restricted the return line - engine running, I can see the pressure going up a lot, so the pump does the job. I suspect the pressure regulator, any other ideas?
Old 08-13-2007, 06:07 AM
Default RE: Low fuel pressure, part deux
ORIGINAL: draser
That sounds like the fuel pressure regulator.
eduard
05-09-2013 12:11 AM
BigOBob
01-01-2012 02:47 PM
piconrule
07-24-2009 02:38 PM
HondaAccordNewb
10-18-2007 06:51 AM
mamtsberg
05-20-2007 09:25 AM
Quick Reply: Low fuel pressure, part deux
