Low Brake Pressure?
Old May 19, 2007 | 04:28 PM
mamtsberg's Avatar
Default Low Brake Pressure?
Long time reader, first time poster. I just replaced the front brake pads on my '01 Accord, 4 cyl (first time do it yourselfer). I took it for a drive and the brake pedal is very soft and goes almost all the way to the floor. It feels like there is not brake pressure or do the new brake pads just need to break in (no pun intended)????? Any thoughts would be greatly appreciated.
Old May 20, 2007 | 08:56 AM
deserthonda's Avatar
Default RE: Low Brake Pressure?
did you pump up the brake pedal several times before you took it for a drive ?? if you did ,and pedal felt ok, but goes to floor now, you might have either an external leak or a bad brake master cylinder .
Old May 20, 2007 | 09:25 AM
mamtsberg's Avatar
Turns out I just need to bleed the brakes. I accidentally removed the banjo fitting?/brake hose and got some air in I think. I'm a novice, but it works now. Thanks for your help though, I love this site.
eduard
May 9, 2013 12:11 AM
zoid_99
Jul 21, 2011 05:14 PM
piconrule
Jul 24, 2009 02:38 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
draser
Aug 13, 2007 06:07 AM
