Sponsored by:
Sponsored by:
Gear problem!
Old 09-13-2009, 06:09 PM
space_walker7
Default Gear problem!
I own 2007 V6 3.0L model
I had a problem ,as I guess, with the gear, after stopping the car for one week.
whenever the engine reached the normal heat, I'm having a problem in reverse;
when I put the gear on the R, simply the car doesn't move, I have to inject lot of fuel to let it work, but not even in proper way.
also sometime the engine RPM goes up in shifting.
I'm checking the car regularly, and I have change the gear oil from less than 7,000 K.M
any suggestion? I need a help
Old 09-14-2009, 08:59 AM
Changed transmission oil 7,000 km ago? What kind of transmission oil did you use?
Old 09-16-2009, 05:09 PM
space_walker7
I'm not sure, as it was the only option in the market,
so as I didn't meet any accord owner who's facing the same problem, I guess it's the correct one.
I have an idea that I want to try, let me hear your opinion about it:
I'm gonna empty the oil and put litter of a cheap oil to make sure all the precipitates will be flushed, afterward I'll refill it again with the good brand.
I think it's a dirt problem after I stopped the car for awhile!
what amazed me, when I took the car to the agency; they told me that I'm facing a transmission problem, and they have to open the gear to check it!
beside the risk of open such a thing, I don't have to mention the amount of money which I have to pay (around 2,700 USD)
Old 09-16-2009, 05:51 PM
deserthonda's Avatar
i assume it is AT tranny??,, you should have used Honda atf -z1 .........also,, how many miles on your car?? less than 3 yrs or 36,000 miles it is still under warranty
Old 09-17-2009, 04:17 AM
space_walker7
I used the ATF - Z1, as I said, couple of month ago only!
and my car's age is, of course, less than three years but I crossed the 36,000 K.M.
I had an argument with the HONDA dealer here about my car, simply they said it's not under warranty anymore.
so I have to find a solution by myself, or as I hope from an expert like you guys..
any advice?
Old 09-17-2009, 06:45 AM
It's very good that you used Honda ATF-Z1, that would have answered MY question.
Where are you located? Warranties are different from one country to another, but 36,000 miles is 58,000 km.
Old 09-17-2009, 09:49 AM
space_walker7
I meant 36,000 mile
I crossed the 85,000 K.M
the warranty should cover my car for open mile up to three years.
but a technical problem happened, as the previous owner of my car didn't take it to serves on a regular base so the warranty been canceled.
so no matter how much I took the car to the serves or I will do, it's still not applicable!
amazing ... right?
letsclique
06-18-2016 04:29 PM
d0n
02-04-2013 08:45 AM
droidboy
04-03-2012 02:43 AM
eckhart
06-29-2011 06:33 AM
Jakehansen
06-04-2007 07:16 PM
Quick Reply: Gear problem!
