Remote Starter Install - Help!
First of, it's not as bad as it sounds. I've put a remote starter in one other Accord and one Civic before without much trouble. So what I've got here is a 2004 EX 4 cyl and a remote starter that utilizes the OEM keyless entry lock button to start the car (press 3 times). So after installing the starter and hooking up the one wire that I thought would get the signal from the keyless lock button to start the car, it turned out that I could only start it by pushing the power lock button three times on the passenger side. It worked, which meant all the ignition wires, etc. were hooked up correctly, just need to figure out where the keyless entry door lock output wire might be. Anybody have any experience in this area? It's got me stumped. I'm so close. Thanks for any help.
JJ
JJ
jagz_accord
06-03-2005 03:05 PM
