transmission hard to get into reverse
Old Jan 30, 2007 | 02:42 PM
ziptie
Default transmission hard to get into reverse
I did a search, and come up with nothing. My daughters 93 Accord with 200k miles is getting real hard to get onto reverse. It has the 5 speed. Any ideas?
Old Jan 30, 2007 | 02:45 PM
sir_nasty's Avatar
Default RE: transmission hard to get into reverse
depending on how long it's been since you've changed the tranny fluid that could help a little bit, it may also be that the tranny is worn a little bit and making it more difficult... On cars that I have owned with that issue typically you can just slowly (very slowly) start releasing the clutch as you are pulling down into reverse and then it should slip right in, re-apply the clutch quickly (so it doesn't jerk or anything) and then drive like normall.... like I said though if you haven't changed that fluid in a while then drain it and re-fill with honda MTF...
Old Jan 30, 2007 | 03:13 PM
ziptie
sir nasty, thanks for the quick reply. I just showed my daughter the trick with the clutch, and it worked. I think I will also change the fluid.
thanks again, Tim
Old Jan 30, 2007 | 03:19 PM
sir_nasty's Avatar
chances are then that it's something either wearing or being a little stiff internally.... I've had a number of cars that almost always required me to do that and they lasted just fine until I sold them...
Old Jan 30, 2007 | 03:24 PM
Can we assume it's not simply excessive friction in the shift cables??
If it grinds going into reverse, maybe the clutch is dragging. Reverse doesn't have a synchro.
Old Jan 30, 2007 | 03:42 PM
ziptie
Jim, there is not any grinding when you put it in reverse, or any gear.
Old Jan 31, 2007 | 12:16 AM
Well, what about misalignment of the shifter, cables, or the levers down on the tranny where the shift cables attach? You should rule out the easier stuff like that.
gabrielbyrnei
Aug 16, 2012 06:53 PM
zodiackiller
Dec 17, 2011 08:24 PM
mencho
Jun 22, 2009 09:11 PM
MrGmo
May 30, 2008 10:18 AM
rwerber
Mar 9, 2007 11:33 PM
