Sponsored by:
Sponsored by:
Engine mount control system question
Old 07-07-2013, 07:41 PM
DonnieVanDango's Avatar
Default Engine mount control system question
I have completed about 98% of my auto to manual swap in my 97 Accord. One thing I haven't seen any information on is the Engine mount control system in the rear mount. Is it ran from the ECU or the TCU? Can I just plug the vacuum line or do I need to do more? The mount is shot. Maybe I need to replace with the same type? Any help would be appreciated.
Old 07-07-2013, 09:18 PM
For the 1997, only Accords with the automatic came with the engine mount control system.
  • 97 4 cylinder automatic had a Powertrain Control Module (PCM) instead of an ECM.
  • 97 4 cylinder manual had an Engine Control Module (ECM) instead of a PCM.
  • 97 V6 had an ECM and a separate Transmission Control Module (TCM).
For the 4 cylinder automatic, the electronic control engine mount solenoid valve was controlled via the PCM.
For the 6 cylinder automatic, the electronic control engine mount solenoid valve was controlled via the TCM.
I would think that you can probably just plug the vacuum line.
Attached Thumbnails Engine mount control system question-l4-ecm-pcm.jpg   Engine mount control system question-v6-tcm-ecm.jpg
Old 07-07-2013, 10:02 PM
Will give it a shot tomorrow redbull.
Old 07-09-2013, 05:29 PM
It might be that even in the non-vacuum state, the auto-engine mount might be softer than the manual-trans mount. So find a mount from a manual-trans in your favorite junkyard?
Old 07-20-2013, 08:16 PM
Thank for all your help. I welded the mount together as a "get by for now". Now, I am using the computer that was originally in the car, 1997 HA F22B2 with auto trans. The computer I got with the 1996 HA had different sized plugs all across the computer so nothing would plug up. Oh, the tcu is built into the computer. So, do I need to just unplug the tcu plug or find a computer that is correct? Is the computer from a 5 speed 97 what I need? Just had back surgery so this may not make any sense. Thank for the help
Old 07-20-2013, 08:33 PM
Can you tell me the part number on the sticker for your PCM and the 96 PCM you got?
They should be something like 37820-p0a-a51.
Old 07-20-2013, 10:18 PM
I can tomorrow. Again, just had back surgery and I'm slow going. Thank you for your reply.
Old 07-23-2013, 11:39 AM
Watch that welded-up engine mount. Without the flexibility of the mount, that weld might fatigue and have a short lifespan.
HwyPilot
03-24-2015 12:24 PM
johncarden64
07-26-2010 05:31 PM
baer77
02-27-2009 03:47 PM
chibiko
04-07-2007 08:49 PM
jlmartin42
11-08-2006 09:38 PM
Quick Reply: Engine mount control system question
