Sponsored by:
Sponsored by:
New manual tranny owner, a few clutch questions
Old 03-31-2008, 04:31 PM
finch13's Avatar
Default New manual tranny owner, a few clutch questions
Well I just bought a 99 sedan with a 5 speed in it. I don't think the clutch has ever been changed and it has 170k on it.
Here's my issue: I can't accelerate too fast in 3 or 4 gear because the clutch will slip, 1 and 2 are fine. If I'm cruising at 70 MPH in 5th gear and I give it some gas I can rev the engine to 5k without gaining much speed. Sounds like the clutch is going out to me.
I have already tried adjusting the clutch peddle free play and it's okay, is there anything else I should look at?
I'm planning on buying a Fidanza 3.2 Kevlar clutch, do I need to resurface or replace the flywheel? For resurfacing do I need to machine it or can I just remove the glaze by hand? (I read somewhere that Honda flywheels have a concave flywheel design and can't be machined like an ordinary clutch...)
Thanks for the input guys!
Old 03-31-2008, 07:21 PM
lightshow's Avatar
Default RE: New manual tranny owner, a few clutch questions
yea your driven disk sounds shot. time for a clutch. the flywheel needs to be machined. also the bolts that hold the flywheel on have thread lock on them ( and youll want to put a fresh coat on them when you put it back in ) so bring your a game. the special crank pulley wrench will work perfectly.
Old 04-01-2008, 09:21 AM
00AccordLX5spd's Avatar
Registered User
I'd probably replace the flywheel. Probably won't cost much more than machining the old one, plus it will give you some peace of mind...
heathzx
10-09-2011 02:37 PM
littleolme
03-19-2010 06:47 AM
Cody Is Cool
06-01-2007 12:53 PM
tamb
07-21-2006 01:05 AM
Markus26
03-07-2006 04:40 PM
Quick Reply: New manual tranny owner, a few clutch questions
